Asus Essence STX II delivers less sound to one channel. (headphones)
Indiana333
Basically what the title says, for some reason after changin motherboards, my sound card now delivers about 50% less volume to my right channel compared to my left one, the headphones are working OK (senheiser hd600).
Any ideas what could be causing this?, I of course checked with the volume mixer and it shows both at 70%.
Thanks.
Varmintbaby
Thanks.
Do you need to turn the headphone gain up in HP Advanced Settings? The little button to the right of the speaker test button in "Main" tab. You may have had the gain set to a higher Ohm headphone previously on your old motherboard and need to set it back?
