ROG ryujin 360 FAN replacement
Dalibor
Hi guys i wonder can i replace fans on watecooling ryujin 360 with thermaltake ,just estetic because that 3 fans doest have rgb...So that means watercooling block has 3cables going out for that 3 fans i was wondering can wottercoling work without 3 original fans with that 3 cables free not conected..
THX in advance
ninezerofive
Sure you can, just get the PWM fans and adjust them in the software to start spinning faster when CPU temps increase and you are all set.
mdzcpa
Level 12
Yes. Easy swap. But as stated above, depending on the fan specs (CFM and static pressure). You might need to set your fan curves a bit more aggressive. The included Noctua fans have great flow and static pressure for use with a radiator. You may need to compensate.
ok guys thx i think im gona leave it from the other side im waiting thermaltake 71 case and its a lot of posibilities to find place for all 20 fans and that radiator
