Asus ROG GL553VD Keyboard Lighting problem
aRonio
Hello!
I have a problem with my keyboard lighting problem, the light works only on the power on/off button but the rest of the keyboard not
I installed ATK Package - ROG Aura Core, everything is under control
I guess it is a hardware problem, what should I do? I know how to dissembly it but i don't know where and what to do
Someone can help, please?
6 REPLIES 6
aRonio
someone?
All things keboard and lighting:
1: ATK package (ASUS Keyboard hotkeys Driver V?.?.?.? your version)
2: ROG Aura Core Component (this is a asus app, not available on your support page. It should be in your esupport folder at this location: C: esupport/edriver/software/Win32App/Asus/)
3: ROG Aura Core (windows store app)
4: Aura Lighting Service and or Aura Service (same thing different versions)
5: you might have a keyboard hotfix (support downloads page)
6: Asus Keyboard Hotkeys (windows store app)
All of these should be in your esupport folder or on you support downloads page.
Uninstall everything (pay attention to the wording of the pop up during your ATK install/uninstall) reboot.
Install in this order:
ATK
ROG Aura Core Component (double click the Setup.exe)
Aura Lighting Service (per instructions on your support downloads page, IE right click run as administrator install.bat file) Be patient sit for four minutes let lighting service fully install.
Keyboard hotfix (if applicable)
Then run Asus Live Update (program) let it update any lighting service or hotfix.
Asus Keyboard Hotkeys (windows store app) reboot
Should now have a functioning factory keyboard, lighting and ROG Aura Core app:) there may be minor discrepancies between our models.
ATK
Still couldn't fix
1. Didn't find ROG Aura Core Component
2. Didn't find Aura Lighting Service
3. No keyboard hotfix
4. Runned Asus Live Update and didnt update any lighting service or hotfix
I think it is a tech problem, i just want to know what to do inside of it ...
aRonio wrote:
Still couldn't fix
Looking at your driver page our models are quite different, sorry I can't help. This is a German site that many people use to find original esupport folders: https://www.asustreiber.de/downloads/download/60-windows-10/778-gl553vd-treiber-dvd //// download the ISO; mount and compare your esupport folder, maybe you can find something. With none of your lights working, maybe it is a hardware problem. Good luck.
aRonio wrote:
Still couldn't fix
Hey there! Did you figure this out? I'm having the exact same problem at the moment and haven't been able to fix it. I'm suspecting it's a hardware issue but not sure.
Cheers,
Blake1
Hello pipecad.
Which model do you have?
And was there any update or modification before the issue occurred?
