Maximus XI code and Corsair H60
Alessio088
Hi guys,I just needed an advice please as I'm finally started to build my new pc.
I'm at the stage where my maximus XI code is installed in the case and I have got the Corsair h60 in place on the CPU too.
I just got a doubt where to link the 3 pin connector from the pump and where to link the fan 4 pin connector.
After reading the instructions I understood that both need to be connected in the motherboard ports that are not controlled by the Q fan control, so the pump will be connected in the port aio_pump and the fan is w_pump+ .
Is that correct?
Thanks in advance
chama
Do you solve that?
mdzcpa
Level 12
Connect the pump header to the AIO header, and the rad fan to any header on the motherboard and simply disable Q fan on that specific header in the BIOS.
Hi Thanks so much for answering,
I've this case with Liquid Cooler integrate, I'm not expert in liquid coolers, should I see water pumping?
https://www.pchunter.it/deepcool-genome-rog-certified-edition-case/
