Battery Protection Asus non-removal Batteries
TurkROG
Hi All
i got my G703 Recently , i need to know the best way to protect and save my battery to live to the maximum time , as i am connecting it always to Charger due to gaming purposes
Any Ideas ? it was great idea if there was small switch to completely cut the battery and rely on the power source only .
Thanks .
xeromist
Even if you have it plugged in it will not charge constantly. Basically it will discharge 5-10%, then start charging again. So it's designed to be OK when plugged in.
