Zephyrus GX701GV - Manual Mode RPM fan issue
Jaroslaw_0
Hi guys,
After activating the Manual Mode in Armoury Crate, the minimum RPM of the GPU and CPU fans are 4000 RPM. You can't change this with the sliders, you can only increase RPM fans. The minimum RPM in manual mode is the same as in Turbo Mode and you can not change it. I would like in manual mode the lowest RPM should be about 2000 RPM during idle and about 6000 RPM during maximum load of CPU and GPU. Is it possible? Even if I set the 0% fan speed they are at least 4000 RPM. Why there is no fan curve? My model: GX701GV
Thanks for help
5 REPLIES 5
Blake1
Hello Jaroslaw_0,
May I have the version of your BIOS and Armoury Crate?
I will double confirm with our technical support.
Hello,
Armoury Crate ver: 2.7.13
BIOS ver: 306/307 - the same situation on both
Regards
Blake1
Hello Jaroslaw_0,
Sorry for my late reply.
I have reported this issue to relate department to double check.
Blake@ASUS wrote:
Hello Jaroslaw_0,
One user of the GX701GX model with a more efficient graphics card (RTX 2080), in response to my problem, wrote to me: (screen attached).
I cannot set the minimum speed lower than 4000 RPM, but the maximum speed can be set to 0% (second picture). It doesn't make sense
Blake1
Hello Jaroslaw_0,
I'm sorry that 4000rpm is the lowest for current design.
Your opinion has been taken in to careful consideration for future improvement and adjustment.
Thank you so much.
