ROG Strix III (G731GW) - External monitor compatibility
fivetech
Hi all,
I'm planning to purchase an external monitor for my G731GW laptop which is Asus VG259QM. Can I take the full advantage of it with my laptop such as Nvidia G-sync and 280Hz using USB Type C to Display Port cable ? My laptop screen is 144 Hz.
Blake1
Hello fivetech,
The Display port on G731GW is 1.4, and VG259QM is 1.2, so it's enough to support it.
Hello guys,
Thank you Blake.
Finally, I have got the monitor. It works directly via RTX 2070 and I observed it gives more fps than internal display. 🙂
