Dimm.2 SSD not detected - Help Needed
TSportM
Level 11
Hello,
This is driving me insane for along time i houve bought another Nvme drive all my M2 are populated
in windows at least it does not show the SSD Nvme
Iam using a 48 lane CPU (10980XE), iam using 16X 16X 8X and dimm 2_1 is enabled
every thing ok acording to specs
86965
86963
it detects the SSD
86964
iam using nvme SSD to boot from M2.1 slot and m2.2 is also with a drive (storage)
any help would be apreciated
Edit:
Fixed, needs to be disabled on dimm2 on the oabove figure its gets detected in the bios in the NVME storage, and show up in windows if you enable Dimm2_1 and Dimm2_2 it will open a Vroc raid after saving for a raid setup and it will not show in he NVME storage until a raid is enable same thing for windows.
Rig1 - 14900KS - P112 - E88- MC86- Pcore 6.0/6.2/6.3 Asus Z690 Maximus Extreme - Ecores 4.7 - 48GB TForce 7200#64;7400ddr5 - MSI Suprim X RTX 4090@3070mhz - 24gb memory speed - Powerby corsair Ax1500i - Corsair1000d@custom Loop Rig2- 10920X@4.9 - Aorus X299 gaming 9 - gskill 3200@3600 - Zotac RTX 2080Ti - Powerby CM1200 - Noctua NHD15 black - Corsair 900D
BigJohnny
Make sure you have DIM.2_2 chosen over the PCIE4. Also check you are in the correct slot. Been awhile since I use both for Intel M.2 drives and Vroc but pretty sure the one closest to the memory is #1.*
This BIOS is pretty hard to navigate and find this stuff. Took me some time to find the place to select DIMM.2_2 *over PCIE4.*
