11-25-2020 11:51 PM - last edited on 03-05-2024 07:30 PM by ROGBot
11-26-2020 07:02 AM
11-26-2020 08:23 PM
Braegnok wrote:
When you were in your BIOS did you check Advanced\Onboard Devices Configuration, there should be a tab for USB power delivery in soft OFF state (S5) with a drop down menu, can you confirm this feature is Enabled.
There is also a Windows setting to wake up a sleeping computer with Bluetooth mouse or keyboard. Open the Keyboard control panel item, click the Hardware tab, and then click Properties. Click the change Settings button. Click the Power Management tab, and than verify that the Allow this device to wake the computer is enabled. Click OK, and then click OK again.
Hope this helps.
11-27-2020 05:11 AM
