Ryujin 360 Micro Fan Not Working
zekikosiff
Hello today I replaced my asus rog ryujin 360 cooler fans with corsair ll120 fans I was unable to control the micro fan via software after changing the fans. Is this normal?
10 REPLIES 10
Vitriolic
I have not replaced the fans and the microfan isnt working either, noticed it today by pure luck.
Did a firmeware update and it spun up for while reinstalling version 0205.
After the installation microfan returned to twitching, every 5 seconds or so.
When you unplug the USB cable, the micro fan starts running at top speed. I could not understand the reason for this
Have you installed Armory Crate and updated all the modules?
With the USB connected to a MB header, and the pump connector attached to the AIO MB header, in Armory Crate under the Ryujin Device, the Radiator fans are controlled under 1 drop down setting (for both fans) and the Micro Fan under another drop down menu choice. Is this were you are trying to control from? The pump is controlled through the BIOS if you want it to run at anything less than 100%.
Make sure your replacement radiator fans are 4 pin PWM fans.
Me and my girlfriend also have a "Ryujin 360", and I also saw that the microphone fan was no longer running.
This is for us because of an update of the software "Armoury Crate"
Because that’s stopping suddenly, my WC is not even 1 years old, and my girlfriend’s under 6 months old. 😞
I just reinstalled windows properly..
MrAgapiGC
The rerport was send the day of AC version 4 was deploy
We wait
I have test all scenarios possible. Will not work. I send the report day 1
Learn, Play Enjoy!
Â* I haven’t noticed my micro fan not working and I have all the AC updates too. I will double check my own rig later tonight.
Have you tried a custom speed setting? Â*I run my own fan curve on that fan. The drop down menu choice is still there?Â*
Nothing changes when I make changes micro fan speed via armory crate
MrAgapiGC
Update has being push now. Please check.
I run a small test and the update put the mini fan to work again.
I will make some checkup and report back later But the update fix it.
If update arrive installed it and restart the pc. but it works now perfect
88416
Learn, Play Enjoy!
88416
fixed after update thank you 🙂
