Asus Dark Hero pump speed
arconz
I'm going to buy a new rig with the Asus Dark Hero and an EK D5 pump. In BIOS what are the options to set pump speed, I know control can be either disabled leaving the pump at 100%, but the pump is 4.8K rpm so would be very noisy. Also a speed curve which might be very annoying if its reacting to CPU temp (my build doesn't have water temp sensor). Is there an option to set it to a specific speed in BIOS, for example 50%?
0 REPLIES 0
