How to fix random crashing for G15-G513QY Ryzen Advantage Edition
MyRyzenWorld
Level 11
Community Member posted it here:
https://www.reddit.com/r/ASUS/comments/q5itgw/how_to_fix_random_crashing_for_g15g513qy_ryzen/?ref=sh...
ASUS G15 G513QY Advantage Edition (AMD Powered) with Radeon RX6800M and Ryzen 5900HX
If you have an Asus G15 with the RX6800M this post is for you. There are 4 variations of GPU firmware floating around and you may or may not be getting the latest which seems to fix the stability issues with this laptop model.
The first thing you need to do is download and run GPU-Z and make sure you are not already on the latest Video BIOS, if you are and you crash then you simply need to wipe and reset the driver stack and that is beyond the scope of this post.
If not then continue reading on:
Talk on Discord:
https://discord.gg/ekBcya2r
Blake1
Hi there,
Let's discuss this issue together with the reboot problem.
