Asus Rog Zenith Extreme Ram Problems
Ivanovits78
My Pc
Asus Rog Zenith extreme with last bios update
Threadriper 1950x
2 set of
RAM CORSAIR CMW32GX4M4C3000C15 VENGEANCE RGB PRO 32GB (4X8GB) DDR4 3000MHZ
total 64GB ram.
I have the pc almost 3 years and never succed to go to 3000MHZ. Always stack so i used to 2133.
The meaning of this post
a.i f somebody had the same ram and succed to fix?
b. Suggestions for ram that works 3200mhz -3600mhz without problems to change them. (I need only 32GB ram now)
thank you.
dejanh
Ivanovits78 wrote:
My Pc
Threadriper 1950x
2 set of
total 64GB ram.
thank you.
Have you already reduced your total memory to 32GB? The main problem in hitting higher speeds with the 1950x and that board was when you exceed 32GB of memory. Generally, 32GB should be able to run at 3GHz at least assuming the memory supports it.
