[SOLVED]
I've just bought a K7 with italian layout.
In aura creator the keyboard displayed is incomplete, is missing "" key (near Z) and ù/§ key (near the Return key).
Since they cannot be selected, it's impossible to customize or simple keep illuminated.
Note that the same keyboard on Armory Crate is displayed complete, and it's possible to change keys, for example.
All software is updated, of course.
Could you kindly check and find a solution, maybe an update?
Thank you in advance.
Regards
SOLVED: I don't know how and why, but today the missing keys are appeared... Maybe a OS update?
