GPU Tweak II FPS counters all disappeared from Monitor panel
gf_finazzi
Hello,
I noticed that after the Nvidia Experience client got updated all the FPS counters disappeared from my GPU Tweak 2 monitor panel. GPU Tweak II it's in its latest version which is 2.3.8.0.
I'm pretty sure Nvidia changed something because all of the other FPS counters I had in the system started having issues, and I had to fix them all, but I was not capable to fix the GPU Tweak II issue they just disappeared from Monitor I don't see any FPS related metric that I can add.
Is it a known issue for which I should wait for an update?
Anyone found any workaround?
4 REPLIES 4
Nate152
Hi Nate,
Thanks for the suggestion, but it didn't work, before posting here on the forum consider I already did all the common troubleshooting steps.
Nate152
Thank you,
I'm using GPU Tweak III, the OSD settings are found below, I'm also using the latest version of Geforce Experience.
91672
cekeu
Level 12
Hello, I am using GPUTweak III for monitoring and OSD screen and it is working fine. I haven't needed to use overclocking yet.
We download it here: https://www.asus.com/campaign/GPU-Tweak-III/
From the https://rog.asus.com/ page only
