TP-Link HS200/210/220 switches get deauthenticated constantly with GT-AX11000
CyberDynamite
I own a GT-AX11000 running with FW 3.0.0.4.386_45934-gb23bdac. It' runs in the regular router mode.
I've got about 95 devices connected. Around 80 of them are wireless and 15 wired. I have all kind of smart devices, i.e. cameras, smart bulbs, smart switches Ring floodlights, Nest smoke detectors, etc.
I don't have any problems with my devices connection with one exception: all my TP-Links switches (HS200, HS210 and HS220) are rebooting randomly. I didn't have this problem when using another router (Netgear Nighthawk R7000) before. Problems have started with these switches only when I started using my Asus AX1000 router.
I have read a lot at the TP-Link forums and they said it was not a TP-Link problem but surely a FW bug in the Asus router.
So, do you think this could be it, a firmware problem? Should I use the Merlin one? Have any of you encountered this issue before and if so how did you fix it?
Update: I saw another post here: https://rog.asus.com/forum/showthread.php?126478-ROG-Rapture-GT-AX11000-Version-3-0-0-4-386-45934-(2... , Post #4
What would be the best firmware to use for my two RT-AX92U (in Aimesh) with the AX11000 with firmware 3.0.0.4_386_44266 ?
NOTE:
Please delete my other post here: https://rog.asus.com/forum/showthread.php?127413-TP-Link-HS200-Switches-get-deauthenticated-constant...
I had created my topic in the wrong section of the forum.
Rihno
Have you tried the latest release?
"New ROG Rapture GT-AX11000 Version 3.0.0.4.386.46065 11/01/2022"
Not yet.
II have another problem with 2.4Ghz band dropping. After a few days, this band keeps denying internet access when trying to connect to it.
So, I'm waiting to see results from other users before upgrading.
