01-23-2022 04:15 AM
01-23-2022 08:46 PM
01-24-2022 01:12 PM
STARRAIN@ROG wrote:
Hi JamesAndersonJr,
Do you only use 1 monitor?
May I know why don't you connect to dGPU with DP?
Please refer to the following link to check the CPU and VGA part.
https://www.asus.com/support/FAQ/1042678
Does it occur on bios 2403 with bios all default settings?
If yes, please enable CSM and then try again.
01-24-2022 01:35 PM
01-24-2022 09:49 PM
04-24-2022 12:01 AM
04-24-2022 05:20 PM
04-24-2022 08:31 PM
04-25-2022 05:25 AM
STARRAIN@ROG wrote:
Hi JamesAndersonJr,
May I double confirm you get 1xlong, 3xshort beeps, and white Q-LED when connecting dGPU via DP every time? Or it is intermittent?
Although you get 1xlong, 3xshort beeps, and white Q-LED, there is no ROG LOGO while POST and you cannot enter bios via pressing F2 or DEL but you can see the win11 log-in screen?
Have you tried with other DP cable and other monitor?
04-25-2022 08:22 PM
