I just changed my headset from Asus Rog Delta to Asus Rog Delta S recently. Delta S doesn't compatible with Armoury 2 software, so i did the same EQ options from Armory Crate for Delta S model. However, I get almost half of the volume compared to Armoury 2. Also, I had the same problem with my previous headset. Are you going to make a version of Armoury 2 for ROG Delta S? Or, can you please fix the Armory Crate.
asusrogdelta.nsx ( Armoury 2 ) EQ best Settings Delta
Armoury Crate Asus Rog Delta S ineffective.
Pls Submit Special EQ Settings for Delta S
