Asus claymore 2 FN function not working and ROG RX switches replacement
dr_alwi
hi every one...
1- i don't know what happen but suddenly Fn function not working , tried every thing but no luck , tried all to uninstall armory with uninstall tool and installed again , but again not working at all
2- so i missed one of keypad and i cannot find replacement , is it possible to remove ROG RX Switches and replaced with usual one in marked ? really i cannot find replacement for keycap of ROG RX yet in the market...
thank you again
8 REPLIES 8
Nate152
Hi dr.alwi
Are you able to change the RGB brightness on your ROG Claymore II by holding down the Fn key and pressing the up and down arrow keys?
This key cap set is compatible with the ROG Claymore II, you might want to double check the layout of your keyboard, being you're from the U.K. it may be different.
https://shop.asus.com/us/90mp0280-baua00-rog-pbt-keycap-set.html
Nate152 wrote:
Hi dr.alwi
thank you for your replay , unfortunately no , instead it pressing the normal arrow .
about the keycap I'm not sure about the layout , that's why I want to change one of switches with regular one with its keycap , so are the switches are removable?
Nate152
Can you be a little more specific, do you want to replace the switch for the Fn key?
Comparing the U.K. layout to the U.S. layout, I do see they are different.
U.K Layout
93096
U.S. Layout
93097
U.K Layout
93096
U.S. Layout
93097
sry for the confusion...
the FN function not working at all , so when i press Fn with arrow up or down , suppose increased or decreased the light , but its not even with other fucntion too ( volume up or down) , is it software issue? i think it happen after update , the problem i cannot reset the key bored because the Fn is not working ( as i read Fn with Esc for seconds)
the 2nd issue , i mean the the same switch , can i remove it? and replaced with other one in the market?
Nate152
Thank you
Maybe there is an easy fix.
Since it happened after an update, try uninstalling Armoury Crate with the uninstall tool from the ASUS Support Center.
Select your operating system then click Show all, it's the third download.
https://www.asus.com/supportonly/Armoury%20Crate/HelpDesk_Download/
After uninstalling Armoury Crate, restart your pc and try the Fn key.
Nate152 wrote:
Thank you
i did that but unfortunately still the same problem....
is there any other way ? what about removing the switch? can be?
Nate152
No, the switches are not hot swappable.
You could try uninstalling your ROG Claymore II from Device Manager, restart your pc and try the Fn key.
MasterC
Community Admin
Community Admin
The optical switch may be faulty, no software issue on my end. Suggest to send back to place of purchase or contact your local ASUS office.
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
