Results 1 to 6 of 6
Thread: Need Help With TUF Gaming Build!
06-30-2022 10:42 PM #1
- Join Date
- Jun 2022
- Reputation
- 10
- Posts
- 4
Hello,
I recently built a new TUF Gaming system but the problem is that ARGB TUF Logo on the LC240 AIO Pump doesn't seem to be working as it should. As you can see below, currently its ARGB cable is connected to the 3-way connector and plugged into 'ADD_GEN_2_1' port however there's no light on it at all but 2x120mm ARGB fans work with the Aura Sync. But if I disconnect AIO Pump's ARGB cable from the 3-way connector and plug it into the 4-pin 'RGB_HEADER' port, it only lights white in breathing mode. No matter what I do, which port I try, with or seperate from the 3-way ARGB cable, I couldn't make it work with the Aura Sync. I also tried reinstalling the Armoury Crate but nothing has changed.
Am I doing something wrong or missing something here?
Below is the schematic of my MoBo.
All LC240 ARGB fan cables are connected into 3-way ARGB cable and plugged into 'ADD_GEN_2_1' port. (11)
All GT501 front RGB fan cables are connected to each other and plugged into 'RGB_HEADER' port. (12)
PC Specs:
-Intel Core i9 12900K
-Kioxia 1TB Exceria PRO NVMe M.2 SSD
-G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory
-Asus TUF Gaming Z690-Plus 1700 DDR5 6000MHz (OC) M.2
-Asus TUF Gaming GeForce RTX 3080 V2 10GB
-Asus TUF Gaming LC 240 ARGB 2x120mm
-Asus TUF Gaming 750W 80+ Bronze PSU
-Asus TUF Gaming GT501 3x120mm RGB MidT ATX Case
Any help or suggestion would be appreciated.
07-01-2022 08:13 PM #2
- Join Date
- Jun 2022
- Reputation
- 10
- Posts
- 4
up+
07-02-2022 01:55 AM #3
pndiode PC Specs Laptop (Model) ASUS G752VL-DH71 Win 11 Pro 21H2 Motherboard ROG Maximus XII Formula Processor I7-10700K Memory (part number) G-Skill F4-3600C19Q-32GTZRB Graphics Card #1 ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block Graphics Card #2 ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block Monitor LG UltraGear 32GN50T-B Storage #1 WD Black SN750 1TB Storage #2 WD Blue 4TB (4 ea) CPU Cooler EK PE 360 (Top), PE 240 (Front), and Xres 100 Elite Case ROG Strix Helios Power Supply ThermalTake Toughpower 1200W Keyboard ROG Strix Scope RX Mouse Logitech MX Master S2 Headset ROG Strix Fusion 300 Mouse Pad Generic Headset/Speakers Bose Companion 3 Series II OS Windows 11 Pro 22H2 Network Router Generic Accessory #1 Corsair ML140 (4 ea), Corsair ML120 (3 ea) Accessory #2 ASUS External 16X BLU-RAY Writer
- Join Date
- Jan 2016
- Reputation
- 31
- Posts
- 302
07-03-2022 12:20 AM #4
- Join Date
- Jun 2022
- Reputation
- 10
- Posts
- 4
07-03-2022 04:34 AM #5
- Join Date
- Jan 2016
- Reputation
- 31
- Posts
- 302
Defective pump ARGB
Lights white in breathing mode when connected to RGB (12V - 4 pin). No light when connected to ARGB (5V - 3 pin).
07-03-2022 09:37 PM #6
- Join Date
- Jun 2022
- Reputation
- 10
- Posts
- 4
That's a sad thing to hear
Thank you for your interest and answers tho.
Highly appreciated.
