07-19-2022 04:02 AM - last edited on 03-06-2024 10:19 PM by ROGBot
07-19-2022 04:31 PM
migu1996el wrote:
Hello
I updated the armory crate and it bugged everything, i cant turn any LED on my pc i cant control the fans and all the info in control panel is missing. really stupid this program is been bugging on all updates and its been a crap since launched. NOW i cant even unistall it since the unstalation tool says filles are missing and cant remove the program. anyone as an idea how to fully remove the program to try a re-instalation ??? i dont eant to reinstal windows because of this crap
Thank you all
07-21-2022 12:48 AM
MarcioTB wrote:
Same thing here! If I update, my G.Skill memos are no longer recognized anymore. I'm using an older version to everything works
07-21-2022 05:02 PM
migu1996el wrote:
Thx! could you please send me your instalation files so i can try to mix with mines to see if i can unistall mine? i cant use the unistalation tool says missing filles,
07-21-2022 05:51 PM
