RTX3080 Bios Help.
Sethryan
Hello, i wish to know if my video card (3080 10gb tuf lhr v2 OC - ID:10DE 2216 1043 8822) has the lastest bios, since i tried enabling resizable bar and i games are unplayable with it enabled. I heard that some cards need to update bios to work correclty. Also ive seen that in V4 bios a beeping noise is fixed on pc turn on that i been having if i dont turn on monitor first.
GPU-z shows: 94.02.71.40.B0 as current bios but doesnt say V3, V4 or V5.....
Can some point me in right direction because i dont wanna brick my gpu with brong bios.
I dont know if asus tool finds and checks if it is updated by itself since i dont wanna mess with things i dont know.
Thanks in advance.
4 REPLIES 4
BillBittel
Level 12
I use the Tech Powerup database to check for latest BIOS. For the TUB 3080 10GB V2 OC they only have one BIOS listed. it is 94.02.71.40.B1added 15-August, 2021. You should also check the Asus support site for that model. The latest VBIOS will be there.
https://www.techpowerup.com/vgabios/236474/asus-rtx3080-10240-210524.
The TUF is a dual BIOS GPU so the version with the B1 at the end may be the OC version.
Sethryan
Any asus guru that can point me in right download?......
Silent_Scone
Super Moderator
Hello,
All the latest VBIOS are available directly from the support pages. V5 seems to be the most current for the 3080.
https://www.asus.com/uk/motherboards-components/graphics-cards/tuf-gaming/tuf-rtx3080-o10g-gaming/he...
Silent Scone@ROG wrote:
Hello,
Ok, so "TUF-RTX3080-O10G-GAMING" is same bios as the OC ? i have the v2 OC lhr. If those share same bios ill flash the one you pointed.
