Hey guys,
Just want to chime in regarding the compatibility of the LSI 9265 and the Asus Rampage 3 Black Edition board running the shipped bios version 0404 (release bios.)
I, too, read the reviews from folks who were having a hard time getting the R3BE to work with this board - however I was in disbelief, so I bought one. (:
The trick is to disable the SATA3 ports on the board. Once you do this, the RAID controller will pop up in the boot options and you can boot without any trouble at all. Make sure to download the drivers from LSI's website, and make sure to remove your removable media before formatting a boot drive (the flash drive you will likely use will mount as c:\ in almost all configurations.)
JIC I save someone some panic, make sure to keep the installation media for windows in your drive I gave myself a panic attack when I received error 0x80300001 thinking I couldn't install to the RAID I had configured... then realized I had pulled the windows media. LOL - you'd think Microsoft would kindly say "Please insert your media...."
I hope this helps! If you see this post in more than one place, it's because I'm hopping around to the different forums correcting this misconception after successfully getting this to work.
Enjoy!
