These are not full professional assembly instruction but I hope they can help someone out. Here is some of the steps you need to take to replace the internal RAM. It's not as hard as it may seem. Just take your time and it'll be easy.
Make sure you have the right tools. I used a small phillips head screwdriver, flat head screwdriver, small pliers and of course the RAM. Oh and I have a small wooden box so I don't lose my screws.
Remove the battery and pop out all the small circular rubber fillers.
With the fillers removed you can now get to the screws.
I place my screws in groups as to not forget where they go. Pay close attention to the different screws coming from under the bottom plate. They are all different sizing. Remember where they go
I forget to take a picture of this but use a paperclip and remove the DVD/CD drive. There are 3 screws under it that will need to be removed.
Once you have the screws remove you can remove the top rear cover.
