How To Set Default Boot Power Plan?
PentiumCore
Hey,
I was wondering if there was anyway my laptop could boot into the "balanced" power plan whenever I start the system.
When I select that option and restart / power off-on it will automatically set itself back to "Power4G High Performance" which means it stays overclocked. I like the Balance option which only uses what it needs.
Now I know by simply selecting the balanced option every time I start up the laptop is a way around it but the thing is... I ALWAYS forget to do this until the time comes to shutdown, and I'm like "damn...forgot to switch it again." lol.
Thanks!
Asus G750JW (Poverty Spec)
17" 1600x900 - 4700HQ - 8GB RAM - 2GB GTX765M GPU
GAMING RIG 2013:
Asus P9X79, i7 3930K, 8GB RAM, GTX780 s/c, 256GB SSD)
GAMING RIG 2006:
Pentium D Extreme Edition 965 (3.8Ghz, 1066MHz, 65nm)
8GB DDR2 1066Mhz RAM (4x2GB) CL5
1GB GTS450 DDR5 GPU
4 REPLIES 4
villiansv
Level 11
You could just remove Power4gear completely and stick with the default windows power management plans, they remember the last one chosen. I don't think there's any actual benefit to running power4gear.
PentiumCore
OK, I've gone ahead and uninstalled it, thanks! - How do I restore it if I needed it for whatever reason?
GAMING RIG 2013:
GAMING RIG 2006:
1GB GTS450 DDR5 GPU
villiansv
Level 11
Should be available from the asus support/download pages.
Pitcher1
please visit asus support site http://www.asus.com/support/ and type your model name then select os and utilities.
