08-24-2014 10:56 AM - last edited on 03-05-2024 10:25 PM by ROGBot
08-24-2014 11:21 AM
08-24-2014 08:12 PM
08-25-2014 06:57 PM
08-25-2014 09:09 PM
08-25-2014 10:03 PM
08-26-2014 01:18 AM
Costas wrote:
Remember that the IMC [internal memory controller] is embedded within the cpu and this may be the culprit.
08-27-2014 07:10 PM
Chino wrote:
Remove all your sticks except for one. Clear your CMOS and upgrade your BIOS to the latest version using the EZ Flash utility in the BIOS. Right after it finishes, clear your CMOS again.
Enable XMP and see if it works with just one stick. If not, go the manual method again. And just out of pure curiosity, please post the exact values that you're using during the manual setup.
Costas wrote:
Since the only thing you have changed is the CPU and everything worked OK previously - It may point to an issue with the new CPU. Remember that the IMC [internal memory controller] is embedded within the cpu and this may be the culprit.
Do you have or know someone with a similar cpu that you can quickly swap and try it with?
08-27-2014 07:29 PM
gjsmo wrote:
No change whatsoever unfortunately. Timings are 9-11-9-9 at 1.65V and 1866MHz.
