System shuts down using offset vcore
Fritz_the_Germ
Yo guys,
yesterday I changed my voltage settings from override to offset mode. Everything seamed to work out fine. prime95, vers. 27.9, ran through without errors or bsod. But after a few minutes in idle my system shut immediately. It was no reboot!
First I thought the psu could be faulty but it was not. So I switched the offset vcore voltage (had +0,250V vcore) back to override (1.31 V) and everything was alright again- beside the fact the cpu is fired up to 1.31 v all the time.
How can I get the offset vcore mode stable? All the other voltage are set in offset mode.
__________________________________________________________________________________________________
Intel 5930K@4.500 MHz@H²0_cuplex kyros HF| ASUS X99-Deluxe, BIOS 1103|NVidia EVGA Titan-Black@1.300 MHz_GPU@2.000 MHzVRAM@H²O_AC_kryographics H²O@Phobya Xtreme Nova 1080@4*180 mm Silverstone AIR Penetrator@neighbour room|SOUND Nubert_NuBoxes@ AVR Pioneer VSX-527-K@ SVS PB-1000, 300 W Sub| Corsair AX 860 W |4*4 GB G.Skill@3000 MHz CL15| LG BH10LS38 Black |Samsung 850 PRO 512 GB@ Seagate Barracuda 7200 1 TB| Corsair Obsidian 800D| ASUS VG 278HR_1920x1080|Windows 7 Prof. 64 bit |
AMD 7800X3D@Watercool-Block&@ASUS Crosshair X670E Hero|NVidia FE 4090@H²O_Heatkiller V Pro H²O@Mo-Ra3|Seasonic Fokus-GX 1000W| 2*16 GB G.Skill&@6200 MHz@30-38-38 |Samsung 990 Pro, Gigabyte Aorus NVMe Gen4, Samsung 850 PRO 1 TB, Samsung 960 evo, 1 TB| Lian Li 011 Air mini | LG OLED55G39LA| Windows 11 Prof. 64 bit
xixou
you could rely on my settings, works fine at my side in adaptive mode with C states activated.
https://www.youtube.com/watch?v=gYHIRinGTH8
Thany ya man. I will give it a try!
xixou
Is that ok at your side ?
