Strix Tactic Pro LED flashing
CraYen
Hi there
Just got Strix Tactic Pro today and the LED which lights the whole keyboard keeps blinking? flashing? every 4-5 sec. Is it possible to just turn the backlight on permanently? I find it very annoying and distracting.
5 REPLIES 5
Heini
Level 11
Hold the "FN" key down and use the 2 & 8 keys on the numbers pad to adjust the brightness. I think it only flashed on the highest setting.
Thanks for the info my friend had the same problem as CraYen
[SIGPIC][/SIGPIC]
OMG, YOU are the (wo)man! That b-R-e-A-t-H-i-N-g was driving me nuts.
Thank you
CraYen
It worked, thank you 🙂
daxliniere
Yep, this thing snagged me up for a bit, too. 😉
Maybe the firmware default shouldn't be the breathing mode?
