PG278Q G-Sync black flash (frame drop) at 144Hz
Crysto
Has anyone else experienced an issue where when running the PG278Q at or near it's maximum refresh rate with G-Sync active causes relatively frequent (several times a minute in some games) frame drops? It just looks like a momentary black flash.
I've tested SLI on/off, multiple Displayport cables, and two different cards DP ports with no change. It appears to be G-Sync only as it doesn't happen in Windows, however by simply setting the displays turbo mode to 120Hz (or lower) the frame drops no longer happen - as soon as it's set to 144Hz it will start happening again.
Even gone as far as confirming it with a high speed (phone) camera!
I'm completely expecting this to be a warranty issue, but would much prefer a simpler solution as I'm happy with this particular panel. 😞
The same issue was posted in this thread, but no mention of a solution: https://rog.asus.com/forum/showthread.php?51400-PG278Q-Random-black-frames-(frame-dropping-)
0 REPLIES 0
