BSOD help please!
Retired
Not applicable
I just bought an ASUS G74SX-BBK8 from best buy like a week ago and I allready have a BSOD I'm not really sure what the cause of it is and I would like to receive as much help as y'all can give me. I received the BSOD when I was doing a windows update and it was shutting down then I got the BSOD. I tried to add the .dmp files but they wouldn't add I zipped them.
Thanks, Sam.
7 REPLIES 7
The_Nemesis
Can you get back into windows? If so try to restore back to a point prior to the update?
Praetor
» i7 990X 3101A239
» Asus Rampage III Black Edition
» Asus GTX 470 & 570 Tri-SLI or Three Sapphire 5850's CFX
» 6GB Corsair Dominator GT TR3X6G1866C7GTF
» Corsiar Force Series 180GB
» CORSAIR Professional Series AX1200 1200W
» Microcool Banchetto 101
Defiant
» G74SX » 16GB ram » Corsiar Force Series 180GB » 750GB Seagate » Blu-ray
Retired
Not applicable
Yes I am able to get into windows. I'm pretty sure I haven't done anything that System Restore would fix I haven't downloaded anything really.
You downloaded and installed a Windows update. I think the rational is that is the update caused a problem, so restore back to before that update.
Retired
Not applicable
But I just installed that update today and according to eventvwr I've had these problems for like the past week.
... but the BSOD, whatever is causing it, started with that update, right? I'd restore back then wait a day or so and see what happens, then try that update again.
Read the User's Manual for more info. 😄
G74SX-A1 BIOS 203
Intel 6230 WiFi/BT
LG E2350 LED LCD Monitor
Intel Series 510 120 GB SSD
Drivers, Apps and How To's
Latest nVidia Drivers
JRd1st on DeviantArt.com
Retired
Not applicable
I found these in the eventvwr:
"- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 2
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2011-12-07T05:29:06.138836200Z
EventRecordID 7735
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer TheGamingBeast
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 159
BugcheckParameter1 0x3
BugcheckParameter2 0xfffffa80071dd060
BugcheckParameter3 0xfffff80000b9c3d8
BugcheckParameter4 0xfffffa800b588e10
SleepInProgress false
PowerButtonTimestamp 0"
"- System
- Provider
EventID 41
Version 2
Level 1
Task 63
Opcode 0
- TimeCreated
[ SystemTime] 2011-12-02T02:53:01.942811300Z
EventRecordID 6204
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 159
BugcheckParameter2 0xfffffa80070f0060
BugcheckParameter3 0xfffff80000ba2748
BugcheckParameter4 0xfffffa80096bd680
"- System
- Provider
EventID 41
Version 2
Level 1
Task 63
Opcode 0
- TimeCreated
[ SystemTime] 2011-11-30T02:00:29.095615100Z
EventRecordID 5377
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 159
BugcheckParameter2 0xfffffa80071d1a10
BugcheckParameter3 0xfffff800049673d8
BugcheckParameter4 0xfffffa800cd8a010
SleepInProgress true
Those are the only 'critical errors' on there, there are also a few normal 'errors' and 'warnings'
dstrakele
Level 14
What Antivirus, AntiMalware, and Firewall software have you installed to your G74SX-BBK8?
What applications have installed to this system?
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
