Maximum CPU Cache Ratio made a huge difference
DosTheBoss
I was seeing bad scores for a DDR4 memory and at the xmp and i was trying to find why
I couldn't find a solution as long as i searched, that doesn't mean i search everything.
So i changed the max cpu ratio to match the multi of the cpu so the NB clock matches the core clock.
The results are surprising especially the write.
Minimum 24 and Maximum 24 set by default.
50441
Minimum 24 and Maximum 37 set with volt on auto
50442
A full set of tests on Aida 64
50443
Anyone else that played with cache ratio and if some results.
11 REPLIES 11
Praz
Hello
Yes, cache speed has an impact om memory performance at higher memory speeds. However, there are few applications that will take advantage of this increased bandwidth. It is normally better to prioritize stability and cache voltage before maximum speed.
Arne_Saknussemm
Level 40
Yes! Cache makes a huge difference for AIDA and some other RAM benchmarks like MaxxMEM 😄
50445
DosTheBoss
Arne Saknussemm how much volts for cache?
Arne_Saknussemm
Level 40
That's 1.33v but the CPU is a good one...apparenly its quite difficult to even get to 4600 at any volts so you have a good chip too :cool:
DosTheBoss
Yea i guess so, asking around some friends with haswells haven't heard anyone getting to that clocks on cache.
I just test now how low the volts can be stable.
Tnx for the reply.
RIacobo
Out of curiosity... what is your LLC/Ring voltages hitting with these settings? I'm running 1.279 vcore with a 127 Bclk and 35 mult, ram is oc'd DDR4 2800(North bridge is slightly faster then cpu: NB 4582MHZ, and CPU 4460 MHZ). My LLC/Ring coltage is hitting 1.587 which is a little concerning. Have it set to auto, and if I drop it down manually to match vcore, the system won't boot.
Arne_Saknussemm
Level 40
I would not run cache voltage that high...aim for 1.3v or less for 24/7 OC
Cache is fine lower than core....only performance increase is really to be seen in these specialist benchmarks...no point running that sort of voltage for cache...drop it to 40 42 and see what voltage auto sets...and then see if you can reduce voltage
Auto on my board goes too high even at lower cache multipliers....I have never dared to see what it would set for 44 for example....I can run 44 cache at 1.18v
cache is just for a bit of fun OCing...this is 1.33v I wouldn`t run that 24/7 either....no need
51293
51293
I just posted a similar question to help increase the cache ratio. What tool do you use to read out your different voltages?
Arne_Saknussemm
Level 40
I look in the BIOS....I do all my OCing in the BIOS
