I haven't managed to find anything on this particular issue I started having a few days ago, but it's difficult to search for, so I apologize if it has been covered.
So I typically play Battlefield 3 or Skyrim with a Samsung 23" LED monitor hooked into the laptop via HDMI. The problem is that, after playing for about 20 minutes, my monitor will go black, the power light will blink (indicating no source), and the computer will seemingly go to sleep. After about 5 minutes I can open the laptop, press the power button, and it will resume Windows.
The odd thing is that when I play on the laptop itself, I do not get this problem.
Monitoring the temps, I get about 85C on GPU on both external monitor and laptop screen, but I get 96C max on the external monitor to 93C on laptop screen.
While 96C seems a bit hot, will the computer force itself to sleep at that temp? I can't find anything in Windows or the BIOS that shows what temperature it will shut itself off at.
Tests I've done so far:
Swapped HDMI cable
Hooked up via VGA to same monitor
Hooked up to different screen
Updated NVidia drivers
All power savings options are set to Never
I've managed to prove it isn't the HDMI port, HDMI cable, monitor, or GPU overheating. Is 96C too hot, or should I be looking somewhere else?
