Help with new build please?
swstealth
(I am aware there is no ROG parts here but I need help)
I ordered a combo deal off of newegg (combo:2449189) and I'm having troubles with it
Parts:
Intel Core i5 - 4690k 3.5GHz
ASUS Z97-E Motherboard
Rosewill ARC-650 Power supply
ADATA XPG 1x 8GB DDR3 1600
Gigabyte GeForce GTX 960
When I put the GTX into the motherboard I get no video from the motherboard or card at all unless, I go into the BIOS and tell it to use CPU graphics for primary monitor it will then boot with the card in but won't actually use the card for video.
I'm not for sure what the problem might be I can use my Uncles GTX 980 with no problem in my computer and the 960 works just fine in his. Any suggestions would be great.
(BIOS are up to date and when the CPU graphics is set to primary the GTX 960 does appear in the device manager)
0 REPLIES 0
