so as the titel says I have a problem with my custom build pc, it's about 1 - 2 years old i think, and i have had this problem since i started it the first time. it's not all games that i have this problem with, but games like diablo 3, league of legends and mass effekt gives me this problem. i have tried to fix it with many solutions but nothing has worked so far. i had hoped that updating my BIOS would do the trick or when i upgraded from windows 7 to windows 10, the problem would have gone away, but sadly that was not the case. i have triede to installe a water cooler to my cpu and made sure to check my temps all the time, but that is not the problem either. but what i have noticed that helped a little, was when i changed a few settings in the nvidia controlpanel and when i went into my BIOS and changed a power setting. commonly believed to be the cause of the problem. but all of this only reduced the problem and did not fix it. all i can say for myself is, that i believe that my problem lays somewhere in my BIOS or CPU, maybe the powercontrol to the CPU since i have seen the voltage on my cpu going up and down all the time, it swings from 17V to 24V so i don't know if that's a problem. also when i was in the BIOS i found a mode called EZ mode and when i'm in there i can change powersettings between (power saving, normal and optimized). but if i try to change to optimized and press "save and reset" it ask's me if i want to change power saving from disabled to enabled. i have also triede to change the power settings in AI3 and in power management. i have also triede to change my graphics to the lowest in the games that i have the problem with, and that did not help one bit either.
i have used these programs to try and find out what the problem could be: CPU-Z, latencymon and afterburner.
