Nate152 wrote:
Hello Tony11
Just to confirm your ram kit is a single 32GB kit and not two 16GB kits, combining ram kits can cause problems.
List your cpu for us too please.
It is a i7 4790..
What are you talking about its a single 32 Kit? I told you they are 4 modules of 8GB each.. that makes 32GB total.
And even if i put 1 module of 8gb in the last dim it doesnt work. Atleast i got it working for 16GB tho.
UPDATE
Let me update the current situation now.
1 DIMM
Slot A1: works, boots
Slot A2: works, boots
Slot B1: 55 error
Slot B2: 55 error
2 DIMMS
A1+B1: 55 error
A2+B2: 55 error
A1+A2: works, boots
B1+B2: 55 error
Even with only 1 dim in the slots, B1 or B2, it gives me an 55 error.
So what now mate? And no its not tighten up, i even reseated the CPU.
