11-01-2015 01:45 AM - last edited on 03-06-2024 01:23 AM by ROGBot
11-01-2015 05:33 PM
ellite wrote:
I bought the Asus G501jw a few months ago, and this issue is getting very annoying.
I am doing some work, and have whatever software running, and I need to change location, so I close the lid on my laptop and it goes to sleep. (I can see the sleep led blinking).
I get to my new location, open the lid again and the computer wakes up, but does a fresh boot. I login again to windows, and all my open windows are gone. It's just like I've restarted the computer when I open the lid.
Any ideas? Is defrauding the purpose of having a laptop, since I can not commute with it unless I keep the lid open.
Thanks in advance.
Regards.
ASUS G501JW
Windows 10 Home 64Bit
11-13-2015 03:14 PM
11-16-2015 12:44 PM
11-17-2015 01:28 AM
ellite wrote:
Ok guys! I was able to solve it.
In my case, step by step:
- Right click the battery icon
- Power Option
NOW DO THIS FOR EVERY PROFILE AVAILABLE (In my case: Power Saver, Balanced and High Performance)
- Change plan settings
- Change advanced power settings
- Sleep -> Allow Hybrid Sleep -> On Battery: ON
- Sleep -> Allow Hybrid Sleep -> Plugged In: ON
And it now sleeps and wakes up as it is supposed to
Hope it works for you also.
11-20-2015 04:08 PM
- Power Option
12-20-2015 06:11 AM
ellite wrote:
Thanks in advance.
Regards.
ASUS G501JW
