Gaming Headset Not Making Any Sound
supprimendi_tyr
My gaming headset isn't playing audio. I downloaded its driver and I can hear beeps in the ear-cans when I plug it into a USB port, but nothing else. What am I doing wrong?
11 REPLIES 11
Korth
Level 14
Probably a driver problem (you installed the wrong driver for that headset) or software problem (you need to install Logitech/Corsair/SteelSeries/etc software to make it work) or some audio setting is misconfigured (muted) somewhere in your operating system.
Possibly a USB problem. Or the headphone jack is improperly connected to the audio source. Or a component in your audio chip/card hardware is dead.
Can you list your system specs?
[/Korth]
Nate152
You can also right click on the speaker on the bottom right of your screen and click playback devices and see that your headphones are set as the default device.
I check there and they are recognized by name as a default device and even make a sound when prompted to do so from there, but I still can't hear anything else like a Youtube video.
supprimendi_tyr
I've got a Corsair Headset device. It has a USB port connector. When I plug it into the front panel, the sPC recognizes it by name and I here its initial tones, but there is no audio when I play a video or the like. I can plug my old earbuds into the headphone jack (not a USB port) and hear videos, and I can plug some old PC speakers into the audio section of the I/O area in the back and get sound, but I can't get sound with my Corsair headset even though the Rampage v Extreme recognizes it.
Nate152
I'm not a big fan of usb headsets they always gave me some sort of problem. Make sure you have it connected to a usb 2.0 port, the blue ones are usb 3.0.
supprimendi_tyr
Okay, just got it and sounds great (lol, I'm giddy)! Nate152, your mention of default device got me looking through my control panel for default devices.
This helped too: http://forum.corsair.com/v3/showthread.php?t=117715
Thanks, guys!
supprimendi_tyr
Counter Strike, here I come. . ..
Nate152
You're welcome
Good to hear you got it working ! 😉
There are enhancements and adjustments if you're not 100% happy with the sound.
