Samsung 950 pro temp
d3a7hpa1n
Hi All,
what is your 950 pro temp ?
my 950 pro 256 idle temp : 63°
i find this link who speak about thermal throttling : http://www.anandtech.com/show/9856/angelbird-wings-px1-m2-adapter-review-do-ssds-need-heatsinks/8
anyone have a method to cold 950 pro m2 drive ? what is your temp after ?
thank you all
20 REPLIES 20
GoNz0-
you need to either fit heatsinks on it or aim airflow at it. in my new laptop the nvme drive has a thermal pad on it direct to the aluminum chassis to cool it.
Menthol
Level 14
My 512GB idle temp according to AIDA64 is 43 degrees c. If you don't mind placing it in a pcie adapter card this looks pretty nice and according to the article it cools well enough to increase the performance is some sustained benchmarks
http://www.angelbird.com/en/prod/wings-px1-1117/
My 512GB idle temp according to AIDA64 is 36 degrees Celsius.
Your idle temp of 63 seems abnormal unless inside a case with zero ventilation in a very hot environment...
LiveOrDie
Level 11
Screen shot of my 950 Pro temps.
54319
Hopper64
Level 15
Just saw this adapter today:
MZ790A Bios 2002, GSkill F5-8000J3848H16GX2-TZRK, 13900KS, EKWB D5 TBE 300, Seasonic Prime TX-1600 ATX 3.0, Asus Strix 4090 w/ Optimus block, Phanteks Enthoo Elite, Asus Claymore 2, Asus Gladius 3, Asus XG349C, Samsung 990, Windows 11 Pro
d3a7hpa1n
i will try tonight with a fan fix near the 950 and post result
Avenger411
Hey,
Mine's around 35-40c. Although i have a good airflow in my case. And everything is watercooled so it helps i guess.
Max
Cpu : Intel 5930K@4.25ghz@1.2v / Cache @4.25ghz@1.20v
Cpu Cooler : Corsair H100i
Case : Corsair 780T
Memory : G.Skills 32GB DDR4-3200mhz CAS 15-15-15-35-1T@1.370v
Motherboard : Asus Rampage V Extreme (BIOS 3504)
M2 : Samsung 950 Pro NVME 512gb (Gaming)
M2 : SSD1 : OCZ RD400A 128gb (windows)
SSD1 : Crucial MX100 512gb (data)
Gfx : EVGA Titan X w/ 980 Hybrid Cooling AiO Liquid Cooler
PSU : Antec HCP-1000W
Monitor : Asus RoG Swift
d3a7hpa1n
With the fan 53° in idle !
54336
I will buy heatsync son like this http://www.ldlc.com/fiche/PB00161579.html and try
post result soon
Thanks all for your help
