12-24-2015 04:26 PM - last edited on 03-06-2024 01:22 AM by ROGBot
12-24-2015 04:39 PM
12-24-2015 06:23 PM
Nate152 wrote:
Hello Piers
Did you get an overclocking failed message when it finally booted?
If you're typing on your pc don't worry you should be fine, it could be due to an unstable overclock or unstable ram.
Reset to defaults and start over, you can do the ram first and run a test to make sure it's stable then move on to the cpu.
12-24-2015 10:56 PM
12-25-2015 01:23 AM
InfernoStorm wrote:
Since you bumped up the voltage and lowered the multiplier and it's stable then likely your system just wasn't stable at the previous setting.
Should just run some stress test for stability because most games don't properly utilize the CPU fully.
12-25-2015 09:30 AM
