(NEW) Intel Management Engine 11.0 Firmware v11.0.0.1205
AKBAAR
Intel ME 11.0 Consumer PCH-H Firmware v11.0.0.1205
For 100-series Skylake-S and Skylake-H systems which come with ME firmware v11.0.x
Get it here:
http://www.station-drivers.com/index.php?option=com_remository&Itemid=352&func=fileinfo&id=2050〈=fr
STEPS:
here is GIF how to do flashing for your Z170 Mobo ( run as admin Command prompt)
http://i.imgur.com/L5jP8d8.gifv
OR
Read here:
http://www.win-raid.com/t596f39-Intel-Management-Engine-Drivers-Firmware-amp-System-Tools.html
14 REPLIES 14
Woodmansee
Hey Akbaar, what are the changes from the last one?
patch notes are not out yet... when it's out I will definitely share
I just hope the FCLK issue on asus VIII mobos is fixed because as if now you can't change FCLK it will be always stuck at 1 GHZ
Woodmansee
Did you want to run faster than 1ghz?
illogik
Thanks for the heads up. This does not fix the fclk issue however. My system still reboots itself twice after changing the fclk in the uefi then boots into windows with it set at 1ghz again.
Damn. me too
actually less than 1 Ghz to O.C the BCLK properly.
Do you have a Steam Controller dongle connected to your pc?
This Caused the "double" cold boot. Unplugging it at start solved the problem for me.
No, I don't have one of those. My system only reboots itself twice when I manually try to change the fclk setting in the uefi. When I leave it set to 1ghz the double reboot issue goes away.
Woodmansee
I see, thanks. 🙂
MNMadman
Yeah, the Management Engine isn't the cause of the FCLK not working.
Something changed between the 1202 BIOS where the FCLK setting worked, and the 1302 BIOS where it didn't work. The 1402 BIOS continued the FCLK setting not working trend.
Basically, if you want the FCLK setting to work, you need to revert to the 1202 BIOS. Note that when you do this, your Management Engine version remains the same. So you can have the new 1205 ME with the older 1202 BIOS.
