04-17-2016 08:43 AM - last edited on 03-06-2024 01:41 AM by ROGBot
04-17-2016 09:01 AM
04-17-2016 09:54 AM
04-17-2016 11:20 AM
04-17-2016 03:24 PM
04-17-2016 04:26 PM
hexaae wrote:
About the issue:
BTW, I'm currently testing this: I changed default USB Hub xHCI and forced Hub Generic USB SuperSpeed and didn't have disconnecting/reconnecting USB hard disk issues anymore in the last 3 hours... Will need some more days of testing to proclaim a victory though.
04-17-2016 05:16 PM
04-18-2016 01:46 AM
hexaae wrote:
As a general rule ignore Intel crapware if you can: MS for sure provides more convenient drivers certified to work fine with Windows 10 x64. Don't expect Intel to know Windows OS better then MS itself even for their own hw)
hexaae wrote:
...and good news: still not had a single disconnect/reconnect issue since! The USB 3.0 HD is correctly recognized and used in SuperSpeed mode without issues, so it really looks like the perfect solution to get rid of this annoying bug.
Let's keep fingers crossed, will test it for some days and report in case.
04-18-2016 04:12 AM
Gps3dx wrote:
AFAIK, intel is the developer of the drivers, MS just "rename" it as theirs, after is passes some MS internal QA.
04-18-2016 01:59 AM
