06-08-2016 11:20 AM - last edited on 03-06-2024 02:12 AM by ROGBot
06-08-2016 03:59 PM
06-08-2016 09:44 PM
06-09-2016 05:02 AM
06-09-2016 11:29 AM
06-09-2016 02:01 PM
Brighttail wrote:
If neither PCI device works there indeed may be a MB issue. I feel sorry for you if you have to RMA it cause I have spent the last 3 months waiting for stock to replace my own and they haven't had any stock with none coming in in the forseeable future. 😞
06-09-2016 07:15 PM
Minsekt wrote:
well my reseller has atleast 10 in stock right now, but it still takes time. the weird thing is that the gpu works in every pcie slot. i dont have another pci device besides the soundcard and the m.2 ssd right now, but ill try a pci wlan card tomorrow too. that way i can rule out if the soundcard/ssd is broken( will double check on the m8formula obviously too). guess i have to stick to the skylake/formula then for a while, i can live with that... :cool:
06-10-2016 10:11 PM
06-11-2016 04:51 PM
06-11-2016 09:45 PM
FireRx wrote:
Are you occupying PCIe 4_8 ? See page 1-19 of the manual on shared bandwith on that slot will disable the M2. if it's occupied it will wont work.
