Gpu upgrade help for g20bm, amd version with 180w power supply?
Moffegreven
Can any one tell me what gpu cards i can upgrade to whit only 180w psu
Rog g20bm it is The amd version
Slipsen
the best card you can use, to my knowledge. Is the gtx 750ti. i used the MSI version before getting another powersupply.
the g20bm comes only with the 180w supply. To use a more powerdrawing card, you have to get the 230w supply and the PCI power cables aswell.
Welsh_Whoopee
Level 11
well the 230watts is the main power brick for the pc, if you have the second power brick which is for the gpu, the limit of card is only limited to the spare cash you have, even the titan x will fit but only founders edition
Welsh Gaming
