ASUS G752VY Cooling fan speed issue.
D0MINO
Hello,
Last weekend I bought my first Asus gaming laptop. But not only for gaming, so I use it without headset too.
The only issue is that cooling fans running on full speed all the time. Speed doesn't change on stress loads or on idle. Temps are all good - on idle 20-30'C, 55-80'C on heavy load (BF4 and GTAV on max)
I can't be the only one that is annoyed by this hairdryer behavior of premium laptop. Or I am the only one with this "max speed issue". This blowing sound gets really irritating after 8h of work.
I hope someone can help me or unfortunately I'll have to return this mean machine.
gtan777x
Are you using an external keyboard? There is a key that will automatically turn the fans to max rpm when you use an external keyboard. I believe it was scroll lock. On the G752 keyboard itself its FN+ Page up. Note the only way to make it go back to normal is to turn it off for a few minutes and on again.
