07-28-2017 11:52 AM - last edited on 03-06-2024 08:20 PM by ROGBot
07-31-2017 03:44 PM
07-31-2017 09:31 PM
fbatista wrote:
Have you tried setting proc_odt to 80 ohm ? I can only boot at the SPD timmings by setting the proc_odt to that value. Also I use 2T cmd rate since its a double rank dimm .
Good luck!
08-01-2017 02:01 PM
08-01-2017 02:07 PM
syldon wrote:
Is that product code correct. All the searches I did came back as b die type on 8GB sticks.
08-01-2017 02:45 PM
muffinman1604 wrote:
here is a link to the RAM (G skill and Newegg)
https://www.gskill.com/en/product/f4-3200c14d-32gtzr
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232560&cm_re=f4-3200c14d-32gtzr-_-20-232-5...
08-01-2017 03:25 PM
syldon wrote:
Strange I was getting the 4 X 8s. Do you have a screen dump of your settings with stilts settings checker?
I will take a look and see what you can probably tighten up to change for 3200. You are using 2 x 16 so I don't how they relate to 4 X 8 yet. I have 2 sticks of corsair 16gb sitting here. If I cant find anything to change then Ill try mine out at the weekend. They are corsair and 16-16-16-32. Trying different timing wont hurt the chips. Worst case is that you will have to force a safe mode boot to change a setting back or reset the CMOS.
Any settings changed should be checked with a memory checking app. Memtest86 or Memtest64. Memtest 64 will run in windows OS. Memtest86 needs to boot to a USB stick. Memtest 86 runs in its own OS, so removes any corruption from drivers etc. It also runs more thoroughly imho.
08-01-2017 07:44 PM
08-01-2017 08:38 PM
syldon wrote:
It looks like you are loading a profile which is not binding. You are actually running at 2133 not 2933, see mem clk ratio top left.
Can you grab you xmp settings from the memory. You can do it via HWINFO or grab the settings straight from the xmp profile reader in the bios. The profile reader is under Tool > Asus speed information then the settings are listed at the bottom.
copy this to add to them
tcl
trcd
trp
tras
trc
trrd_s
trrd_l
trfc1
trfc2
trfc4
tfaw
tccd_l
List them by columns Jedec, XMP #1 and XMP#2. I only have 2 jedec and XMP#1.
Have you put any voltage settings in at all or are you running on auto?
08-02-2017 12:00 AM
