creaking sound
jin950821
I hear a creaking sound on the left side near the touch pad. I think its coming fromhard drive. I bought this recently not even a month yet. The model is GL702VM. Should I bring it to a service center?
Bahz
Level 12
Hi there,
This doesn't qualify to be posted in this section, for your issue you should contact technical support for help first and they will let you know if you need to send it back for RMA.
Thanks.
