[G73SW-3DE] Flashing screen while using 120hz
evandroo
Well, as the tittle said my laptop started to flash the screen. It was working perfectly but this week i dunno what happened to it. The screen keeps flashing when i try to use 3d or when i put 120hz refresh rate.
Already tried to install old nvidia drivers but it wont work. Im thinking about to make a video showing the problem.. is this really necessary?
So:
Problem: Flashing screen while using 120hz
OS: W7
Machine: G73SW-3DE
Tries:
a- Installing nvidia old driver (265.96)
b- Tried system restoration but not worked
c- Without battery this problem dont happens
Help me asus or anyone !
8 REPLIES 8
fuzon1337
Hi
Have you tried to restore your notebook to an earlier point when this didn't happend?
Asus G73SW-91058V 3D
- Intel Centrino Ultimate-N 6300
- BIOS 205
fuzon1337 wrote:
Hi
Hi! Thx for answering.. i tried it now but not worked =/
ColonelS
Hi there,
since you already did restoring to no avail. Have you consider doing a clean install for your G73?
http://forum.notebookreview.com/asus-gaming-notebook-forum/468027-complete-walk-through-doing-clean-...
Click ->Republic of Gamers<- official Facebook page
ColonelS wrote:
Hi there,
Im going to try this restoration this week.. i hope it works cuz this screen flashing bug is really annoying and "common" on asus laptops... Im luck that my 60hz still working fine aswell
yo Updates:
I removed the battery and im running normally 120hz without any problem.. dunno what happened but it working when i use my laptop without battery.
Any advices?
dstrakele
Level 14
It sounds like you could possibly have a bad battery. I recommend you PM Chastity@ASUS on this forum and open a case.
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
Well the problem is back.. thats not an battery issue.
I think its when the gpu gets a lil hot or something around 60º, 70+
But with battery the problem happens everytime.
Thanks for answering ill contact that guy.
Mason
This issue is most likely a bad or incorrect cable. We have the correct cabled and Chastity will be able to set up an RMA to have you send the unit in to be fixed ASAP.
