Aura Reverts to Color Cycle
joypunk
I've got my Aura set to use the Temperature setting while on and be "off" when the PC is powered down. I haven't seen any pattern yet but sometimes when I boot back up in the morning the settings have reverted to "Color Cycle" for both on and off states.
My motherboard's LEDs were not working at all so I used the Aura Firmware Reflash/Recovery tool (https://rog.asus.com/forum/showthread.php?94418-Aura-firmware-reflash-recovery-tool) and it got them working again. I've had this issue before and now again after using the recovery tool, though.
Windows 10 x64
Bios 1501
Aura v1.05.22
6 REPLIES 6
toxzl2
Same thing happening to me with new Aura software... What is going on with this motherboard? So annoying!
danoz0r
Same problem. I feel your frustration -_-
sadaharu
Same Here.
AURA is just doing whatever it feels like to do.
Leds are always on even i turned my pc off. But in different colors.
Sometimes color cycle some times rainbow.
This update is just terrible.
Monochrome
Same here. I hope it will get resolved soon. Aura is the most annoying part of C6H 😕
Zatarot
I'll chime in with my gripe, when set rainbow and gradient is chosen after adjusting the range and hitting apply the software seems to forget the bottom slider exist and cannot be adjusted ever again only way to adjust it again is to uninstall and reinstall aura.
toxzl2
Which is the best stable AURA version? Thanks!
