Help to Overclocking cpu
AnonGhost
Level 11
hi everyone,can someone help me to overclock my new cpu?
my syste:
MB ASUS Z270E
CPU INTEL CORE I3-7350K
RAM CRUCIAL BALLISTIC SPORT LT 8GB 2400MHZ
SSD WD BLACK 256GB
MB: ASUS ROG STRIX Z370E - GAMING
CPU: INTEL CORE I5 - 8600K
CPU COOLER: Thermaltake Floe Riing RGB 240 TT Premium Edition
GPU: ASUS STRIX GEFORCE GTX 970 OC
RAM: 16GB - 2x8GB G.SKILL Trident Z RGB DDR4-3600MHz CL18-22-22-42 1.35V
16GB (2x8GB)
PSU: EVGA SuperNOVA 850 G2 850W 80+ GOLD
109 REPLIES 109
Nate152
Hi AnonGhost
Nice a dual core kabylake cpu, let's see if it overclocks as well or better than the quad cores. 🙂
Do you have a cpu stress testing program, cpu temp and voltage monitoring program ?
AnonGhost
Level 11
dude i'm newbie 😄 so i have only AI SUITE also download realbench aida64 also hwinfo
but i don't now how to overclock
16GB (2x8GB)
Nate152
Ok great !
You have the tools to overclock your cpu, you can do it with AI Suite but I prefer to do it in the bios.
Will overclocking in the bios be ok with you ?
AnonGhost
Level 11
okay let's do it
16GB (2x8GB)
Nate152
All right
Your bios might be a little different than mine so bare with me.
Go into the bios and set the AI Overclock Tuner or AI Tweaker to Manual.
Sync all cores
Set the cpu core ratio to 45, both cores should show 45
Scroll down and set the CPU Core/cache voltage to manual and enter in 1.30v in the "CPU Core Voltage Override".
F10 and Enter
Once in windows open Realbench and HWinfo.
Click start in Realbench and monitor temps and voltage in HWinfo.
Vcore is the voltage, you can see the temps near the bottom in the 1st column. Let me know what the maximum temp and voltage is after running the test.
67284
AnonGhost
Level 11
okay bro,i'm try
16GB (2x8GB)
Nate152
ups and i have first blue screen DPC WATCHDOG VIOLATION
system restarted on realbench benchmark on video encodig
16GB (2x8GB)
AnonGhost
Level 11
yea bro i'm try to overclock,i'm change setting in bios as you told me but i set cpu ratio 50 and voltage 1.420 and i also activate 5g os profile so system now 5ghz and under bench,after test i will upload screenshoots
p.s sorry for my bad english
16GB (2x8GB)
