09-25-2017 10:47 AM - last edited on 03-05-2024 09:56 PM by ROGBot
09-25-2017 11:58 AM
09-25-2017 12:26 PM
09-25-2017 06:36 PM
09-25-2017 08:37 PM
09-26-2017 09:41 AM
Nate152 wrote:
I like shooters too and for shooters you want smooth game play.
The ASUS monitor I posted is 60Hz which means a maximum of 60FPS, anything over 60FPS you'll get screen tear and a funky mouse feel, so no it will not be smoother at 80 FPS with a 60Hz monitor. At 1440p you'll want to turn on Enhanced Sync to cap the Frames Per Second to 60. At 4k you'd want Enhanced Sync off as you likely won't be hitting 60 FPS with most newer games, as long as you're at or below your monitors refresh rate turn Enhanced Sync off.
My monitor is 2560 x 1600 60Hz and with V-Sync ON (AMD's Enhanced Sync) games are smooth, 60 is the absolute minimum you want to game at. My monitor has an 8ms response time, the one above has a 1ms response time. The biggest difference between 144Hz and 60Hz is probably motion blur and you'll have it at 4k too, the 1ms response time may help eliminate a little motion blur. As you can see in the video the motion blur isn't that bad.
So you're question is do you want to game at higher FPS with no motion blur (1440p-144Hz), or keep 4k and game at 60 FPS. With your hardware you should pretty much be able to run all new games at 1440p with the highest game settings (except for maybe antialiasing) and keep pegged at 60FPS.
Decisions Decisions 🙂
09-25-2017 08:58 PM
09-26-2017 10:32 AM
09-26-2017 10:57 AM
09-26-2017 03:38 PM
